Message 1 of 4
Premium phone screen goes off too quickly
How can I get the screen to stay lit for longer ?
It goes off too quickly if you are trying to write down a displayed number to check it.
3 REPLIES 3
Message 2 of 4
Re: Premium phone screen goes off too quickly
Hi @rufford155 I've taken a quick look at the user guide and that doesn't appear to be something that you can adjust, sorry.
Neil
Message 3 of 4
What model number is that?
If it's the 8600, check the screen saver options, step  3 on page 64 under the heading Handset Display Options
Message 4 of 4
Thanks Neil, I had trawled the guide and gone through all the menus on the phone and came to the same conclusion.
I posted here in the hope I had missed something.
It will knock down the score when I review.
Les - It's just a BT Premium Phone, I don't know what an 8600 is !
