Newbie
Message 1 of 6
Problem with 1571 light
I have a BT Decor 2200 handset. The 1571 light is lighting up after all messages have been deleted. Also, when you lift the receiver the dial tone is interrupted which usually also means a message is waiting.
Has anyone come across this?
5 REPLIES 5
Message 2 of 6
Re: Problem with 1571 light
@John57
Who provides your phone service?
Call diversion also gives an interrupted tone with BT Retail.
Newbie
Message 3 of 6
I'm with Sky, but I don't have call diversion.
Message 4 of 6
Then that sounds like problem with the Sky exchange, as you should not get interrupted dial tone, which is why the phone thinks to have a call waiting. I am also not sure if its compatible with the Sky exchanges.
As this is a BT Retail customer forum, you will need to post on the Sky user forum, as this forum cannot help with this.
Sky User - The unofficial support forum for everything Sky!
Newbie
Message 5 of 6
Thanks, I'll try Sky forum.
Newbie
Message 6 of 6
I have just tried switching off the router and switching it on again and that seems to have solved the problem.
Thanks.
