I have been running a bt flex 500 wifi hotspot x2 without issue for a few years. Using them for wi-do and wired gaming off hotspot. In recent days the connection lights were red on base and hotspots would be slow then drop out. Thought maybe the bt gear had come to the end of its life so replaced with bt 600 mini wifi-kit, same problem, initially can start up, slow, then drops out. Anyone else solved this problem? Btw on the day this first happened had a power cut, but this is not unusual as I live in a remote location and has never caused a problem previously.
