Brodie9666
Newbie
Message 1 of 3
Quick Y/N Question about Whole Home
Hello,
Just a quick question, i have just bought and set up a Whole Home network, i have 4 discs, one for each corner of the house. It's not a big house but i think the walls must be made of lead because it seems my house is where wifi signals go to die!
I have the 4 discs working reasonably well, but when i search for a signal i see the new BT Whole Home mesh Wifi Network, but I also see my router's 2.4 and 5.1 networks.
So the question, should i disable my Router's Wifi signals?
I wonder if it may help the BT Whole home signals out by giving them less congestion to fight through.
Any thoughs?
Thanks in advance
Brodie
2 REPLIES 2
Message 2 of 3
Re: Quick Y/N Question about Whole Home
Yes, turn off the hub wifi, it doesn't form part of the mesh in any case.
Brodie9666
Newbie
Message 3 of 3
Brilliant, thank you very much, you're a star!
