Message 1 of 2
Re: BT Smart Baby Monitor - parent unit beeping at night
Hi. Having the same issue  here. Did you work out what the problem was/ how to fix?
1 REPLY 1
Message 2 of 2
I've now solved this. It's the alarm setting. Ours had somehow defaulted to 6 hours. Switched off, problem solved.
