Message 1 of 3
Re: BT Smart Hub 6. What colour BT WIFI Discs are compatible?
I have a BT Home Hub-6 I’m just wondering weather the BT whole home Wi-Fi disc’s the AC1200 model are compatible with my Hub/Router
2 REPLIES 2
Message 2 of 3
@Tommy42
The BT Whole Home (White) discs will work with any router, but one disc must always be connected to an Ethernet port on the home hub, so you need at least two discs to create a wireless mesh.
Message 3 of 3
Ok @Keith_Beddoe  cheers mate for the info much appreciated 👍🏻
