Franules
Message 1 of 4
Re: Factory reset Whole Home WIFI
Hi
One of my discs won’t reset. It is permanently purple - any suggestions?
3 REPLIES 3
BrunoN
BT Devices Expert
BT Devices Expert
Message 2 of 4
Hi  @Franules, try plugging the disc you're trying to factory reset into your router with an ethernet cable, then press the pinhole to reset it.
Make sure you keep the main disc plugged in when you do this (so that you disc gets its settings from the main one).
Hope this helps.
Franules
Message 3 of 4
Hi
Thank you. I did this already. The third disc won’t do anything except show purple - doesn’t even flash. That’s why I tried to reset.
BrunoN
BT Devices Expert
BT Devices Expert
Message 4 of 4
Hi again, someone else here had the same problem and got a solution, which someone successfully used again yesterday. Does that help?
If that doesn't work, contact the helpdesk using the details on that other thread.
