meri_gadi
Message 1 of 2
Re: Smart Hub 2
I have 5 whole home wifi discs hardwired back to Smarthub 1. The setup works perfectly.
Can i still use the previous whole home wifi discs with the Smarthub 2 without purchasing new discs?
Can they still be hardwired?
Would i be able to remove 1 disc nearest to the Smarthub 1 and use Smarthub 2 as a disc itself?
Sorry if its offtopic.
1 REPLY 1
licquorice
Message 2 of 2
Re: Smart Hub 2
So why change it?
No, but I guess you could use it as a wireless access point but it wouldn't be part of the mesh
