Message 1 of 2
Re: Smart hub 2 and wifi disc disconnects
I have had the same problem. I have re-installed the wifi disc twice and after about an hour it will disconnect and show the red light. To solve the problem, I have to switched off and on and then it will stay blue for about an hour and then go red again. please Help @JohnC2
1 REPLY 1
Message 2 of 2
Hi @vincentlau_uk, welcome back and I've moved your post to create a new thread as the previous thread was a few years old.
Sorry that you are having a problem with one of your complete wifi discs. Have a look at Fix Complete Wifi Problems and see if that helps.
Have you had a replacement wifi disc as it may be that the disc itself has developed a fault?
cheers
John
