Shelldybeld
Message 2 of 3
Re: Wifi Disc pairing issue
Hi can anyone please advise, I have received a new disc to pair with my home hub 2 . I have had the hub for 18 months and can’t find the yellow earthnet cable to set them up. I have a spare grey one but seems it won’t connect with this.i assume it has to be the yellow one? Thanks
2 REPLIES 2
Shelldybeld
Message 1 of 3
Hub disc
Hi I have been sent a disc to improve internet in house extension, trying to set up but I do not have the yellow earthnet cable that came with hub over a year ago. I have another earthnet but not working so I assume it has to be the yellow one. Thanks
albertj
Recognised Expert
Message 3 of 3
Re: Hub disc
Hi @Shelldybeld
Welcome to the Community!
You can use any ethernet cable to connect. But, if it is not working when you connect the disk using the cable to your router; you can put the devices close to each other and press the WPS Button on both disk and router.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
