suxrule
Message 1 of 8
Really slow BTHomeSpot but only on iPhone?
Hi,
This issue is really bothering me, mainly because there is very little to no other reports of it that I can see.
We have a couple of BTHomeSpots in the house that work brilliantly with every device connected to it...except my iPhone.
Speed tests on all devices (Xbox, iMac, android phones) come back as 30+ mb but the iPhone on both HomeSpots comes back below 0.5 mb.
Can anyone think of a reason this might be happening?
Thanks for any help.
Tags (1)
7 REPLIES 7
Keith_Beddoe
Message 2 of 8
Re: Really slow BTHomeSpot but only on iPhone?
Welcome to this user forum.
Does it connect at the right speed on the BT Home Hub?
suxrule
Message 3 of 8
Sorry yes forgot to say it connects perfectly on the main router.
Keith_Beddoe
Message 4 of 8
Did you clone them to the home hub, or do they have their own separate SSID?
suxrule
Message 5 of 8
They have their own ssid, didn’t know you could clone.
Andrew600
Message 6 of 8
It may not be anything worth worrying about.
Are you using Bluetooth? If so, turn it off and try again.
It badly affects Wi-Fi speed tests on my iPad. My 70mbps connection reduces to a reported 4mbps if I test with Bluetooth active, but only for the iPad. The actual connection is 70mbps for every other device.
Keith_Beddoe
Message 7 of 8
Its best not to, as that can cause issues.
Sounds like some form of wireless incompatibility.
suxrule
Message 8 of 8
Thanks but Bluetooth doesn’t seem to be affecting it. Iv searched the web high & low and there doesn’t seem to be anyone else having this issue, it’s very strange....and frustrating.
