Mon to Fri 9am - 5.30pm Saturday 9am - 2pm
Hi @4hawk4,
We have a helpdesk that may be able to help you.
You can reach them on 0808 100 6116:
DanielS
@4hawk4 Have you updated to the latest firmware ?,
Yes I've updated the firmware today, which initially worked fine, but I've had to turn off the discs a few times in the last few hours, and they seem to have finally connected up, but not in the way they should. i.e. strongest signal. I'll keep an eye on this over the coming days.
@4hawk4 Did you do a cold reboot on all discs after upgrade, ie switched off the power,
Yes it took a few goes at this, but they seem stable now, fingers crossed
