juliembaker
Message 1 of 6
Registering an additional BT2700 handset
I am having trouble registering an additional handset because I don’t know the PIN number. Can you tell me how to find it, or obtain a new one?
5 REPLIES 5
Zombie
Expert
Message 2 of 6
Re: Registering an additional BT2700 handset
If you have never changed it then it’s probably 0000.
juliembaker
Message 3 of 6
Thanks - I’ve tried 0000 but kept getting “Failed”
Zombie
Expert
Message 4 of 6
I’ve just looked through the instructions and the default pin is definitely 0000. You might be best doing a reset of the phone so the pin is reset to 0000.
‘The documents can be found here..
http://bt.custhelp.com/app/answers/detail/a_id/56791/~/bt2700-nuisance-call-blocker
juliembaker
Message 5 of 6
Thanks for your help. I’ve reset the PIN to 0000 and tried to register again. Still no luck - I get the “failed” message again. Any suggestions as to what else I might be doing wrong?
juliembaker
Message 6 of 6
After I replied to your last post I tried again. I now seem to have 2 handsets marked “handset 1”. The original one works fine. When I try to dial out from the second one I get a message “the number you have dialled has not been recognised “. Any idea what I am doing wrong?
