Message 1 of 2
Rename BT black Powerline adapters
Hi all,
My Dad has bought some second hand black powerline adapters and they have an SSID which is not the same as the house/router. I'm wondering if it is possible to rename them as the same SSID.
I'm sorry if the question is wrong - I'm just going off what he asked. There were no instructions with the adapters and he is a few miles away to drive over.
Thanks all,
Gareth
1 REPLY 1
Message 2 of 2
Re: Rename BT black Powerline adapters
Personally I would leave them with a different SSID, that way you know what you are connected to and can force a change to a stronger signal if necessary.
You can change the SSID by accessing the management page of the adapter at its IP address.
