aliw30
Newbie
Message 1 of 4
Repeaters?????
Dear all - first time poster!
I have a BT 3960 (additional hand set to my base unit) which I want to use upstairs - it has a terrible reception there though.  I have read that a repeater or extender could help boost my reception but am confused as to the compatability. Could anyone advise the correct repeater product that I need to buy .  Many thanks
Message 2 of 4
Re: Repeaters?????
Welcome to this user forum.
See http://bt.custhelp.com/app/answers/detail/a_id/38640/~/bt-dect-repeater
Ring the product helpdesk if you want to check for compatibility.
It does say only.
BT Diverse 7000 Plus Range
BT Diverse 6210, 6250, 6350, 6410, 6450
BT Freestyle 7250 & 7310
It also seems very expensive, so you might be better to move the base unit, or install an extension cable, and put a wired phone on the end.
Communityhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
Message 3 of 4
Re: Repeaters?????
Just to add, you should not really have any issues with those phones, within a normal house, unless you have something causing interference.
aliw30
Newbie
Message 4 of 4
Re: Repeaters?????
Thanks for the link - I'll investigate!
