dawvit
Message 1 of 1
Replacement Hub from BT
Hello,
I have received a replacement hub from BT the model I had was the "Ultrafast Smart Hub" the one they have sent me is "BT Smart Hub -Type B"
I notice type  B has no telephone port, I never used this anyway but does anyone know the difference between these hubs?
Also, there were some odd devices left on it...
a couple of unknown ethernets and a USB "TOSHIBA , TransMemory"
Is this normal?
Many Thanks,
David.
