Message 1 of 2
Replacement Smart Hub issues
OK, so, after having an engineer come out and say that my issue appears to be the router (Smart Hub type A) I ordered a replacement and was sent a seemingly identicaltype A.
I have swapped them today and all appeared fine, I'm using a BT Whole Home 3 disc set too so I turned the WiFi off on the new router - same set up as before all connected up faultlessly,  but I did a general restart of the discs anyway.
Issue is - after much messing about!! Disney app, BBC news app, Prime music and a number of other apps will not work through the new router, if I swap the old router back in, the apps work. I have fire TV sticks and mobiles, and all are showing the same issue. Only difference is the router.
Can anyone suggest what could cause this?
1 REPLY 1
Message 2 of 2
Re: Replacement Smart Hub issues
have you turned of smart setup
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off
