Message 1 of 24
Returning Complete Wifi
Hi,
How do I return Complete Wifi? It's been a nightmare to set up as the mesh network interferes with Sky Q's, and with the limited 5 Ghz channels to choose from I can't move them far enough apart!
Thanks.
23 REPLIES 23
Message 2 of 24
Re: Returning Complete Wifi
I’ve got Sky Q and the new Smart Hub 2 with BT Complete WiFi and everything seems to work as it should. I believe the Sky Q connects to the 2.4 band, not the 5ghz. Could that be the problem?
My guess is you would need to call 0800 800150 to arrange cancelling/sending the kit back.
Expert
Message 3 of 24
Ring 0800 800 150 and do a DSR revert, this can only be done within 14 days of the service starting, any longer and you can no longer change your mind.
Why not ring support instead, they'll be able to help you, I have Sky Q and the original smart hub, they work fine together using the 2.4GHz frequency.
Message 4 of 24
The Sky Q Mesh works on 5 GHz channel 36. Putting the SH2 on anything other than channel 36 should work.
Message 5 of 24
It may well do, but the Sky Q box should connect to the 2.4 network on the router for stuff that is delivered via the internet - thumbnails, catchup, downloads, etc.
Message 6 of 24
Hi @Paul_31.
mesh network interferes with Sky Q's”
Apologies, but I read that as being interference and not a connection problem to the SH2.
Message 7 of 24
@VeteranISPUser Hi, could be. Maybe the OP will add more info, although it sounds like they’ve had enough and just want to get rid of the Complete WiFi stuff.
Message 8 of 24
Sky Q "master" is connected to the router via BT Gigabit powerline adapter as they are in separate rooms, BT TV works fine on this connection, but Sky Q shows connected / disconnected to router or internet every few seconds, hence no on demand or downloaded programmes. Best location for the Complete Wifi disk was shown as the room in which the Sky Q mini box is, mini dropped connection to master due to other 5Ghz signal. Cannot move 5Ghz signal on Sky Q at all or on HH6 v2 far enough away to stop overlap, my wifi shows overlap even on channel 64, hence my Zyxel 8924B10 router is happily sitting on channel 100!
Moderator
Moderator
Message 9 of 24
Hi @sja681
Thanks for your posts and welcome back!
Sorry for the problems you're having setting up complete wifi.  Could you send us over your details and give us the opportunity to help get you up and running?
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
Message 10 of 24
Hi @sja681
You can change the SkyQ box to channel 44 but with a smaller channel width, via the Installer Menu.
Press Home button
Move down to highlight Settings but don't press enter
Press  0 0 1 then enter
Then select Network
