ozsat
Recognised Expert
Message 1 of 20
Returning an old hub
Is there anyway of getting some packaging to return an old BT hub - without going  through telephone calls etc?
using Superfast Fibre 2 Unlimited with BT TV Box Pro (UHD/HDR).
Tags (1)
19 REPLIES 19
RIC9380
Message 2 of 20
Re: Returning an old hub
As far as I'm aware you can now return an old BT Hub to any EE/BT shop. Make sure that you get and retain a legible receipt to avoid any potential future argument.
Keith_Beddoe
Message 3 of 20
If its an old hub which was issued to you as part of a contract, before 13 December 2019, then you can simply take it to your local recycling centre.
After that date, it must be returned to BT, to avoid being charged for it.
ozsat
Recognised Expert
Message 4 of 20
Thanks - it has been sat in a cupboard for a couple of years following an upgrade. So tip it is I guess.
licquorice
Message 5 of 20
You could always re-purpose it as a wireless access point if you have any poor wifi coverage areas.
ozsat
Recognised Expert
Message 6 of 20
We actually get very good WiFi coverage from the current hub but the broadband speed itself is poor.
lnajr02
Recognised Expert
Message 7 of 20
See Returning an old hub for the latest way to return it
Hydeandseek
Message 8 of 20
Fantastic - thank you!
Getting that sorted this afternoon.
Have a great evening!
Debben1987
Message 9 of 20
This isn't correct information I'm afraid - do you work for BT?
licquorice
Message 10 of 20
No idea whether the information is currently correct or not, but as the post giving the information is over a year old it may well have been correct at the time.
