Hopeful2
Message 1 of 7
Ring time
How do l extend the ring time on my BT4500 phone?
6 REPLIES 6
Carlusha
Recognised Expert
Message 2 of 7
Re: Ring time
See page 43 of the User Guide.
BT4500 User Guide
lnajr02
Recognised Expert
Message 3 of 7
Re: Ring time
see User guide at http://bt.custhelp.com/app/answers/detail/a_id/45625
assuming your don't have 1571 then you can extend the ring time before the Answer phone cuts in.
Hopeful2
Message 4 of 7
Re: Ring time
Thank you for the info. I presume that because l use 1571 that the ring tone is set to 6 rings. If l use the answer phone and disconnect the 1571 l should be able to extend the ring.
Hopeful2
Message 5 of 7
Re: Ring time
Thank you, very useful.
lnajr02
Recognised Expert
Message 6 of 7
Re: Ring time
Correct if you have 1571 or call minder, that will cut in, nothing to do with the phone, but no call minder or 1571 the you can extend the phone past 5 rings.
Hopeful2
Message 7 of 7
Re: Ring time
Than you. Very useful.
