StarBar42
Newbie
Message 1 of 4
Router position
My modem is a Openreach Echolife HG612. I need to move the router about 5 metres away, is the short ethernet cable supplied essential, or can it be replaced with a cat 5e,  either crossover or standard ethernet cable?
3 REPLIES 3
Message 2 of 4
Re: Router position
By all means use a longer Ethernet cable.  Just a straight one, not a crossover.
Message 3 of 4
Re: Router position
just replace it with longer cable
Message 4 of 4
Re: Router position
Any length of standard Cat5e up to 100 meters will work OK.
