Nicgo13
Message 1 of 10
Router problems
Wi-Fi buffering several times while watching Netflix. Wired connection does not work no lights flashing. Equipment less than 2 months old.
9 REPLIES 9
Keith_Beddoe
Message 2 of 10
Re: Router problems
Welcome to this user forum.
If its a home hub 6, then its probaby broken. Ask BT for a replacement.
Nicgo13
Message 3 of 10
Re: Router problems
How do I know if it is a hub6
imjolly
Message 4 of 10
Re: Router problems
Once the hub is connected and light blue then there is no flashing lights whether wireless or wired
try factory reset by pressing the recessed button on the back and holding until lights flash. If that does not fix it then try and get a replacement
Keith_Beddoe
Message 5 of 10
Re: Router problems
It will say on the home hub, its often called the smart hub.
http://bt.custhelp.com/app/answers/detail/a_id/51940/~/whats-the-difference-between-the-bt-hubs%3F
Nicgo13
Message 6 of 10
Re: Router problems
I am referring to network traffic lights on the wired port at the back of router not flashing, no connection no traffic no lights
imjolly
Message 7 of 10
Re: Router problems
If it's a hh6 then there is no flashing lights on the Ethernet ports on the back when in use
Nicgo13
Message 8 of 10
Re: Router problems
It connects to a switch which does have lights and so does the tv.
imjolly
Message 9 of 10
Re: Router problems
Try the factory reset
imjolly
Message 10 of 10
Re: Router problems
have you tried connecting to hub with ethernet and then to pc/laptop missing out the switch
