PC1977
Message 1 of 5
SH 2 firmware
I’ve had my FTTP installed for a month now and my hub is still on firmware version 15, I know it’s automatic but surely it shouldn’t take a month for the system to pick up that it needs updating to v17
any thoughts?
4 REPLIES 4
imjolly
Message 2 of 5
Re: SH 2 firmware
You just have to maintain connection as there is no manual method
supertedster
Message 3 of 5
Re: SH 2 firmware
Check the TR69 entries, in the event log, to see if the hub has downloaded a new firmware and is waiting to reboot. There may be quite a few pages to scan through!
I don't know if the SH2 auto re-boots? I kept checking the log on mine until I spotted it had downloaded it and rebooted it manually. It had been connected for a couple of weeks. First on VDSL then FTTP.
Cheers
Ted
imjolly
Message 4 of 5
Re: SH 2 firmware
Normally the firmware will auto update and the hub will reboot automatically.
if you think it will help then factory reset the hub but I would not do that often
PC1977
Message 5 of 5
Re: SH 2 firmware
Hub updated over night
