Message 1 of 4
SH2: switching "Full Fibre (FTTP) Mode" to OFF
Hello, I have a BT "Fibre Broadband (VDSL)" service (80Mbps down, 20Mbps up) and I recently received from BT a Smart Hub 2. I have no openreach modem and the phone line plugs into the grey broadband port of the SH2. Everything works nicely, no complains.
I noticed on the smart hub web manager pages that the "Full Fibre (FTTP) Mode" is ON; accordingly one of the yellow SH2 Ethernet ports does not work when connecting LAN devices.
It seems the devices was shipped to me with a "Full Fibre (FTTP) Mode" setting not matching my service option.
Can I safely switch the "Full Fibre (FTTP) Mode" setting to OFF thus gaining a fourth Ethernet port? Or there's a reason to keep the ON setting for a VDSL service?
Thanks in advance for any suggestion.
3 REPLIES 3
Message 2 of 4
Re: SH2: switching "Full Fibre (FTTP) Mode" to OFF
Switch to off. No problems
Message 3 of 4
Ive noticed the same with a Smart Hub I was sent a week or two ago.
I'm also on a FTTC connection (I'm)patiently awaiting FTTP to be rolled out here....
I'd like to know are there any potential side effects of having FTTP Mode set to On on a FTTC service?
Would it do any harm having It on?
BT Halo 3+ (FTTC) | BT Digital Voice | BT Sport (on Sky Q) | Stretham, Ely
Message 4 of 4
only disadvantage to leaving in 'on' position is your 4th ethernet on hub is WAN whereas if 'off' it is a LAN port
