iyiy
Message 1 of 2
Scam network?
Hi,
My wifi network starts with BThub6.
I've noticed recently that a 2nd network has appeared below which is identical to my usual one, but starts with BThuj6
Is this normal or a scam network?
1 REPLY 1
itsjamielike
Message 2 of 2
Re: Scam network?
Sometimes this will come up, it happens from time to time with some devices and some hubs. Don't worry about it. Turn your hub and device off, and then switch it back on if it bothers you. If you turn off your hub but this device still is there. (When it should not be broadcasting because it is off), then it could be something else. Your devices wont connect to it anyways.
If all that fails just turn everything off and put it all in the bin.
IT Tech for 9 years in the Private and Public Sector, recently giving it up for a totally different career change.
