Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Is it possible to set the BYWholeHome discs to have different wifi names for 2.4Ghz and 5Ghz rather than using a merged network?
Hi @kdhmiles sorry you didn't get an answer to your query. You would be best to contact the Whole Home Wifi product helpdesk as they will be best placed to answer this for you.
cheers
John
Hi @kdhmiles , no this isn't possible and would defeat the object of the whole home network system.
Let us know why you're trying to do this and someone may be able to suggest an alternative.
Thanks for replying.
I have a home camera that has a sync module connect to my BT Whole home. I have had issues where it stopped working and the vendor mentioned to set-up my network as separate 2.4/5G network names.
I've told them this is not possible and they now suggested whist listing the MAC addresses of the sync module on the router access list within the BT Whole Home. Is that possible?
