Message 1 of 2
Setting up 5ghz network
Hi I'm trying to set up a 5ghz network as I've got one screen saying it's on and another saying it's off. I've tried to search for it on a 5ghz compatible device with no luck. Can anyone tell me what I am doing wrong? Many Thanks
1 REPLY 1
Message 2 of 2
Re: Setting up 5ghz network
@Parker09
Perhaps you have turned it off by mistake?
This thread shows how to turn it off, so you should be able to see how to turn it on.
https://community.bt.com/t5/BT-Devices/Disabling-5Ghz-on-the-Smart-Hub-2/td-p/1992466
