Gwyndy
Message 1 of 2
Siting of WiFi repeater discs
Does each BT WiFi repeater disc have to connect to the SmartHub2 - e.g. if disc1 has a strong connection to the Hub will disc2, out of range of the Hub, connect to disc1 if it can get a good signal from that?
1 REPLY 1
Gwyndy
Message 2 of 2
Re: Siting of WiFi repeater discs
