rob38
Message 1 of 3
Sky connection
I purchased Whole Home WiFi discs a while ago and changed Broadband/phone provider to BT a couple of weeks ago as I was having connection issues with the then provider +net and decided that using the BT Hub 2 should be a better option using the BT discs.
I have connected all the discs through the BT Hub individually and used the Hub Wireless password on the Sky set up however I keep getting cant connect to router and/or no internet connection and seem to be resetting daily. I am obviously doing something wrong with the set up of discs/router and Sky and would appreciate any help/advise as to what. The IP on Sky for the Hub is on Auto.
I set the discs up as per procedure for Complete Wi-Fi .
I note on the Hub 2 Manager it says Internet not connec ted, not acting as a hotspot ??
Any advise appreciated
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Sky connection
Deleted
rob38
Message 3 of 3
Re: Sky connection
connecting Internet on Sky Q box whats not to understand?
