Had smart hub 2 and complete WiFi 3 days and already a replacement hub is in the way. The new hub resets every night which then results in the 2.4ghz failing to transmit. Rang BT after doing all tests etc and have concluded it must be faulty. Not too impressed so far .........
mine has worked without any problems hopefully 'just one of those things' and new smart hub 2 will be ok
I’ve just ordered one so I hope it solves the problem the firmware update on HH6 is causing with iPhone 7 &6
Someone Solved Your Question? ![]() Please let other members know by clicking on ’Mark as Accepted Solution’ | Helpful Post? If a post has been helpful, say thanks by clicking the ratings star. |
Hi @warrior sorry to hear that you are experiencing a problem with your Smart hub 2.
We will be happy to help you get this problem resolved if you send us over your details. Please click on my profile and select the contact the mods option.
Cheers
John
