froschling
Message 1 of 11
Smart Hub 2 - Changing the default WiFi password
I've just installed my new Smarthub 2 but cannot change the default Wireless Key. The system accepts the change but when I go back to it it's reverted to the default.  Any ideas what I'm doing wrong ?
John
10 REPLIES 10
Message 2 of 11
Re: Smart Hub 2 - Changing the default WiFi password
there should be no spaces
Message 3 of 11
John
Hi @froschling
Obviously a pure quess, but are you sure you have hit [Save]? Also are you making the change connected to the Hub by Ethernet cable. I don’t know if this helps but it makes sense changing wireless while connected by wireless may not be the best idea.
Message 4 of 11
See http://bt.custhelp.com/app/answers/detail/a_id/14110/~/how-do-i-change-the-wi-fi-password-on-my-bt-h...
You can change the wi-fi password via the My BT app.
    1. Open the My BT app and select Home Network
    2. Select Settings
Changing the wireless password on your BT Hub
    1. Select Network settings
    1. Select Change wi-fi password
    1. Enter the current wi-fi password
    1. Enter and confirm the new wi-fi password
Message 5 of 11
There is a bug with the Smart Hub 2 that lets you enter disallowed characters but doesn't tell you, it just refuses to save instead!!!
froschling
Message 6 of 11
Thanks for your suggestions.
I connected via Ethernet and not only did I press SAVE but the hub confirmed it. Even so when I returned to the page the adult password/key was still there :-(
Message 7 of 11
Try a different browser.
froschling
Message 8 of 11
I was able to enter the new WiFi password using the App as you suggested,
Many thanks !
froschling
Message 9 of 11
Ahh that's entirely possible as I was using some punctuation in the new password. A pity it doesn't reject it and tell you why ! Thanks for your suggestion. I'll bear it in mind when next I change the WiFi password.
froschling
Message 10 of 11
Good suggestion ! Thanks !
