The_judds_35
Message 1 of 5
Smart Hub 2 Firewall causing connection issues
Hi,
Has anyone had any luck overcoming firewall issues in the smart hub 2?  I’ve changed from a home hub 5 and didn’t have any issues. I have the same problem when connected with a Ethernet cable direct to the smart hub, so it’s not a WiFi issue.
I get server connection issues on MS Teams and Skype for Business on my Lenovo laptop, my wife’s HP laptop does not get the issues on the same software.
If I put my Lenovo laptop in the DMZ setting I’m ok, but this causes VPN issues on the HP laptop.
Ive now tried a lot of different settings but no luck, port forwarding etc. I think I will return the new equipment to BT, while it does work It is not compatible with my devices (but the home hub 5 is!)
Has anyone managed to resolve an issue like this? Thanks.
Tags (2)
4 REPLIES 4
imjolly
Message 2 of 5
Re: Smart Hub 2 Firewall causing connection issues
have you turned of smart setup
Turn Off smart setup
The_judds_35
Message 3 of 5
@imjolly
Yes I’ve turned this off but it hasn’t helped. Any other thoughts? Thanks
imjolly
Message 4 of 5
have you also checked web protect is turned off by going to MYBT
The_judds_35
Message 5 of 5
Yes @imjolly   Checked that, I think I’ve tried the obvious and it has me stumped!  Thanks for you replies.
