Kian
Message 1 of 23
Smart Hub 2 Firmware
Hi can anyone please tell me the latest firmware version for the Smart Hub 2 and the Wi-Fi Discs as I have heard there was a newer firmware released a while ago.
My Smart Hub 2 Current Firmware: v0.15.00.06145
My Wi-Fi Disc Current Firmware: 0:15:00:05300
22 REPLIES 22
VeteranISPUser
Recognised Expert
Message 2 of 23
Re: Smart Hub 2 Firmware
Hi @Kian   v0.16.02.08304-BT and 0.16.00.07230. Mine updated 23 Dec.
Kian
Message 3 of 23
Did your router and disc auto update the firmware or did you have to update them manually?
VeteranISPUser
Recognised Expert
Message 4 of 23
Hi @Kian   It updated automatically (I don’t believe you can do it manually). I had to reboot the Disc for it to pick up the update. You could try a SH2 reboot to see if it is waiting.
pippincp
Sage
Message 5 of 23
You cannot manually update the hub firmware. Don't know about discs.
Kian
Message 6 of 23
Thanks for the info, no update waiting so will wait for it to roll out to my area.
Message 7 of 23
My Smart Hub 2 is still on @Kian  version of firmware, although it’s due for an automatic 14 day reboot in 5 days time, which should produce any updates....
Never had to manually update the (black) disk firmware in the past. It’s only one disk in my setup.
Kian
Message 8 of 23
Just a quick update, Router has done it's 14 day reboot but still no newer firmware. will see what happens on the next 14 day reboot.
Paul_31
Message 9 of 23
@Kian My system recently rebooted and no update for me either. It would be nice if BT gave some clue about when updates are being rolled out, and even better if they posted somewhere what updates/revisions any new firmware delivered. Always seems to be a bit of a mystery.
Kian
Message 10 of 23
@Paul_31  I spoke to BT the other day about firmware updates and all they said was "When the router reboots on it's cycle, if there is any update then it will pick it up automatically"
That is as much as I got from speaking to BT directly.
