matekaneve
Message 1 of 5
Smart Hub 2 - Is it worth the upgrade?
I'm a BT Fibre Plus customer and just wondering what people think about the new Smart Hub 2? Is it worth to upgrade from the original smart hub or not? Thanks for your answer in advance!
4 REPLIES 4
Message 2 of 5
Re: Smart Hub 2 - Is it worth the upgrade?
No. Unless you have wireless black spots where adding a wireless disc might help.
Message 3 of 5
Welcome to this user forum.
http://bt.custhelp.com/app/answers/detail/a_id/51940/~/whats-the-difference-between-the-bt-hubs%3F
What is wrong with what you have?
The smart hub 2 is really intended for the Complete WiFi Solution package, is that what you are after?
Message 4 of 5
Its not an upgrade in my opinion, it is worse than the Smart Hub 1 as it is not possible to split the wifi bands on the Smart Hub 2.
matekaneve
Message 5 of 5
Nothing is wrong with my current hub, it works fine and I have no issues with signal. I was just wondering if the hub 2 could offer something I could benefit of. But reading through now the comments I'm not going for it. Thanks everyone for the answers!
