michael226
Message 1 of 2
Smart Hub 2 - UPnP
A quick hub set up question.
I have turned UPnP off in the hub settings as I don't use it and understand it can be a possible security risk.
Should I also set Extended UPnP security to off, or is it irrelevant is UPnP in off?   The hub recommends leaving it on.
Thanks.
1 REPLY 1
licquorice
Message 2 of 2
Re: Smart Hub 2 - UPnP
I would have thought it was irrelevant if UpNP is set to off and therefore would have thought that the option to set Extended UPnP security would be disabled. However, as you are aware it isn't though. I have rightly or wrongly set both to off.
