MikeLanglois
Message 1 of 8
Smart Hub 2 USB ports (USB2 or 3)
Hi there,
Is the USB port on the Smart Hub2 a USB 2 or a USB 3 port? Cant seem to find out the information online.
7 REPLIES 7
licquorice
Message 2 of 8
Re: Smart Hub 2 USB ports (USB2 or 3)
USB 2
MikeLanglois
Message 3 of 8
Shame. Ok thanks very much
licquorice
Message 4 of 8
Not only that, but if you use the port for a hard drive, it uses smb1
MikeLanglois
Message 5 of 8
That is one of the things I was looking to doing. Guessing thats bad?
licquorice
Message 6 of 8
It's just very slow. You also need to enable Smb1 in W10 as it is disabled by default.
If you are not worried about speed, the port works ok, I use it to connect an external hard drive for backups.
MikeLanglois
Message 7 of 8
How slow are we talking, and is there any hope they will enable SMB2 or anything better?
I was going to use it to connect a hdd to my laptop wirelessly for occasional data transfer / backups, so slow wouldnt be a problem unless its like 50kbps lol
licquorice
Message 8 of 8
I guess it depends on the number and size of the files being transferred as much as the total size, but somewhere between about 40Mbs and 64Mbs. A 169GB backup took about 8.5Hrs and a 10.5GB about 20 mins.
