Moderator
Moderator
Message 11 of 106
Re: BT Smart Hub 2 and USB connecttion
Hi @RodT  sorry you are having this problem with your Smart Hub 2 and the USB over the weekend. Are you still experiencing this fault? If so I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 12 of 106
Re: Smart Hub 2 and USB
Hi @Tallmat  post back and let me know how you get on with the advice above this evening. If you are still unable to resolve the problem I've sent you a Private message explaining how you can contact the forum moderation team and we will be happy to look into this further for you.
Cheers
John
Kudos”Kudos”
sBerry81
Message 13 of 106
I am also having the same issue since the firmware update over the weekend. I can no longer access my usb hard drive through the BT Smart Hub 2
Thanks, Simon
Moderator
Moderator
Message 14 of 106
Hi @sBerry81  welcome to the forum and thanks for posting. Sorry to hear that you are also experiencing this fault.I've sent you a Private message explaining how you can contact the forum moderation team.
Cheers
John
Kudos”Kudos”
Message 15 of 106
What version is the firmware?
Message 16 of 106
@JohnC2
I am having the same problem since the SH2 firmware update  I can no longer see the USB in windows explorer although hub says USB connected
current firmware  v0.13.03.02221-BT
sBerry81
Message 17 of 106
Firmware version:v0.13.03.02221-BT
Firmware updated:Sat Jun 15 02:13:53 2019
Moderator
Moderator
Message 18 of 106
Hi @sBerry81  thanks for checking that.
The hub team have got back to me to check a few things with and @RodT
Would you and answer the following questions for them?
When was it working? – has it always worked?
What the filesystem format is? FAT/NTFS etc..
Volume name? Example: Daves-drive
What actions have been tried? Reboot? Another drive/usb?
John
Kudos”Kudos”
Moderator
Moderator
Message 19 of 106
Hi @Tallmat  The product team are investigating this issue. Would you kindly answer the following questions to help diagnose the issue?
Cheers
John
Kudos”Kudos”
Message 20 of 106
@JohnC2
just tried a standard 16gb USB stick in SH2 and explorer saw it right away and pc has full access to USB
