Moderator
Moderator
Message 11 of 157
Re: BT Smart Hub 2 and USB connecttion
Hi @RodT  sorry you are having this problem with your Smart Hub 2 and the USB over the weekend. Are you still experiencing this fault? If so I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Moderator
Moderator
Message 12 of 157
Re: Smart Hub 2 and USB
Hi @Tallmat  post back and let me know how you get on with the advice above this evening. If you are still unable to resolve the problem I've sent you a Private message explaining how you can contact the forum moderation team and we will be happy to look into this further for you.
Cheers
John
Message 13 of 157
I am also having the same issue since the firmware update over the weekend. I can no longer access my usb hard drive through the BT Smart Hub 2
Thanks, Simon
Moderator
Moderator
Message 14 of 157
Hi @sBerry81  welcome to the forum and thanks for posting. Sorry to hear that you are also experiencing this fault.I've sent you a Private message explaining how you can contact the forum moderation team.
Cheers
John
Message 15 of 157
What version is the firmware?
Message 16 of 157
@JohnC2
I am having the same problem since the SH2 firmware update  I can no longer see the USB in windows explorer although hub says USB connected
current firmware  v0.13.03.02221-BT
Message 17 of 157
Firmware version:v0.13.03.02221-BT
Firmware updated:Sat Jun 15 02:13:53 2019
Moderator
Moderator
Message 18 of 157
Hi @sBerry81  thanks for checking that.
The hub team have got back to me to check a few things with and @RodT
Would you and answer the following questions for them?
When was it working? – has it always worked?
What the filesystem format is? FAT/NTFS etc..
Volume name? Example: Daves-drive
What actions have been tried? Reboot? Another drive/usb?
John
Moderator
Moderator
Message 19 of 157
Hi @Tallmat  The product team are investigating this issue. Would you kindly answer the following questions to help diagnose the issue?
Cheers
John
Message 20 of 157
@JohnC2
just tried a standard 16gb USB stick in SH2 and explorer saw it right away and pc has full access to USB
