lewisjml
Message 1 of 2
Smart Hub 2 and White Whole Home WiFi discs
Is there a way to configure a pair of White Whole Home WiFi discs to work with the Smart Hub 2?
1 REPLY 1
albertj
Recognised Expert
Message 2 of 2
Re: Smart Hub 2 and White Whole Home WiFi discs
You can, but you can't use the Smart Hub 2 as a wifi point so you would have to plug a white dish into your Smart Hub 2 and then you can use them.
There's another thread from January about this, if it helps: https://community.bt.com/t5/BT-Devices/BT-Smarthub-2-and-Whole-Home-Wifi/td-p/1915687
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
