Message 1 of 3
Smart Hub 2 firmware
Hi all,
I was given a relatives unused hub over the holidays, had it running for a couple of weeks but is stuck on v0.16.01.08093-BT. Although it seems to be checking a few times each night/morning:
17:07:30, 29 Dec. CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 4 VALUE CHANGE
17:07:30, 29 Dec. CWMP: Initializing transaction for event code 4 VALUE CHANGE
17:05:47, 29 Dec. CWMP: HDM socket closed successfully.
17:05:47, 29 Dec. CWMP: HTTP authentication success from pbthdm.x.x.x
17:05:47, 29 Dec. CWMP: HDM socket opened successfully.
17:05:47, 29 Dec. CWMP: Set Parameter by TR069 Success.
Been through the cycle of resetting and restarting in the hope of triggering something but no joy. Any other suggestions?
2 REPLIES 2
Message 2 of 3
Re: Smart Hub 2 firmware
You just need to leave the hub connected 24/7. Constant resetting trying to get firmware to update will have an adverse effect on your connection speed ending in a banded profile
Message 3 of 3
Sorry, I should have worded that better, was online for a week+ before I had a look to see if anyone else had a similar experience. A poster had success with resetting it, so thought it was worth a try the once, been online since.
