mzzuzer
Newbie
Message 1 of 13
Smart Hub 6 - Bridge/Modem mode
Hi,
Just wanted to know if the Smart Hub 6 can be used in modem mode.
Currently with Virgin and their equivalent of the Hub allows you to set it as a modem, which allows another router to be connected to it.
There seem to be a lot of conflicting viewpoints... maybe someone has a definitive up-to-date answer for this please.
12 REPLIES 12
Message 2 of 13
Re: Smart Hub 6 - Bridge/Modem mode
Welcome to this user forum.
No, it cannot be used as a modem.
mzzuzer
Newbie
Message 3 of 13
Hmmm.... someone called Dave at BT Connections said it could be.
Message 4 of 13
I think you will find the same reply from other forum members. You would have to buy your own modem if you wanted to use your own wireless router.
mzzuzer
Newbie
Message 5 of 13
Great start with BT then by the sound of it. Someone at BT says i can, a BT community Forum member says i can't 🙂
Message 6 of 13
Absolutely cannot use as a modem only. You can turn off DHCP and wifi but it will still be routing and natting.
Message 7 of 13
I suppose if you had enough of them, you could make a bridge :smileywink:
mzzuzer
Newbie
Message 8 of 13
Can the hub be positioned away from the Master socket? In my current set-up with Virgin i have the 'hub' in the living room. My own router is at the back of the house and has hard-wire connections from 3 pc's going into it. The back of the house is also the best place for Wireless connections to work. No need for my own router if the hub can be placed anywhere i.e Not where the phone is (in the hallway)
B1998
Message 9 of 13
I think the reality is they might be both right and the devil's in the detail. It may depend the type of broadband and exact hub model you have? Some hubs may be configured to work with an ethernet type connection into your home, some others as A/VDSL routers (even if they're both called 6). I know this was the case for older types of hubs, but not sure about smart hub 6 onwards.
A hub expert would have to answer that specifically...
Message 10 of 13
If the master socket has a filtered faceplate, you can wire from the data extension terminals to a remote RJ11 socket using CW1308 cable.
