flintstones
Message 1 of 12
Smart Hub 6 - Port Forwarding 3389 - remote desktop issue
Hello All,
I am trying to set up the RDP with a new Smart Hub 6. Previously I had a home hub 5 that did what I wanted without issues. In fact I have only done the change over yesterday.
I have followed the guide as to how to add the new port forwarding rule successfully, and adding the port 3389 when prompted and using the TCP protocol, but I am unable to access my machine externally (using NoIp - I have set up the appropriate details in the DNS screen).
Using an internet check of the port, it states that it is closed. If I simply swap to my Home Hub 5 and carry out the same check, the port is open. So I am comfortable that it is an issue with the hub.
I am using windows 10 with Norton and I am happy that all my settings for RDP are accurate, especially knowing that I have recently been able to remote on (with the HH5) .
It appears that BT Support do not want anything to do with this and suggested that I come here to find a resolution!  It can be done, but they won't explain how. While I have had a look here, I've yet to find a fix.
Thanks for looking.
11 REPLIES 11
licquorice
Message 2 of 12
Re: Smart Hub 6 - Port Forwarding 3389 - remote desktop issue
Try turning off UPnP.
I assume you have given the device you are forwarding the port to a static address on the device itself and not relying on reserved addressing from the HH.
flintstones
Message 3 of 12
Thank you for your response.
UPnP is already off.
With regards ti the static IP, I'm using NoIP credentials which I've set up on the SH6. Does that answer the question?
licquorice
Message 4 of 12
No, that is with regard to your public IP address.
You are forwarding the port to a LAN IP address (in the range 192.168.1.XX), has that address been allocated as a static address on that device or are you relying on address reservation on the hub to allocate the correct IP address. If the latter, I suggest you allocate a static address to the device rather than rely on the hub.
Anonymous
Not applicable
Message 5 of 12
Can you RDP over the local network using a static IP address for the target device
flintstones
Message 6 of 12
Just so that I’m clear use a 2nd computer on the same wireless network to try and RDP?
if that’s the case then yes, will give it a go. But in a couple of hours....
thanks
Anonymous
Not applicable
Message 7 of 12
thanks
Yes, that's what I mean.
If you cannot bottom it out then you could always download TeamViewer instead, it's free for personal and 'educational' use and well proven
licquorice
Message 8 of 12
Can you answer my question please, does the target device have a static IP address set on the machine itself?
licquorice
Message 9 of 12
Are you sure you are forwarding the port to the IP address of the target machine or are you just copying the settings of the HH5. If the target device is just getting its IP address via DHCP then it is quite possible that it will have a different address when connected to the HH6 than when it is connected to the HH5.
flintstones
Message 10 of 12
Hi Licquorice
With regards to your earlier question about the static IP, I'm using a noIP credentials that is assigned to a static IP. (i may not have the right terminology!)
To your last question, when setting up the port forwarding on the HH6, you have to select from a list of target devices. In this case I'm selecting the computer name itself and I checked that the IP matches that presented in ipconfig.
The way that SH6 (Smart Hub) and HH5 manage port forwarding is different.
HH5 - you have to select from a long list of possible options as to what the port forwarding would be used for. In the list is Microsoft Remote Desktop, you do not enter the port number anywhere.
SH6 - you have to explicitly enter the port number you're interested in for internal and external as well as In and Out.
For both you select the TCP and the other setting that you mentioned earlier (to Off) in thread.
I hope that this answers your questions
