tonyw1
Message 11 of 88
Re: Smart Hub (6 type A) Firmware update.
That's odd.
Dippu
Message 12 of 88
B540 is not the latest firmware. Mine updated to E016 from B540 last week
Burmey
Message 13 of 88
Mine ends E016 but the firmware date says 21st Nov 2018. Will check when this actually happened in the log if this really is the most recent update ...
Does anyone know what I should be looking for in the event log to determine whether there has been a software upgrade - or will it be obvious?
Dippu
Message 14 of 88
I think there is a software glitch, as mentioned earlier mine updated last week but date shows 28 November 2018
Burmey
Message 15 of 88
....makes you wonder what other glitches there are in this software version....mine hasn't changed speed all week - at all, and it usually changes daily a bit up and down. I thought I'd been banded because I had a lot of outages in early hours of 25th May, but apparently I haven't so maybe the reason for no change is this firmware? Don't know, but it's odd.
B13blues
Message 16 of 88
Got the 4th June showing on mine. Hopefully the 14 day reboot will have been ironed out this time.
clever_trevor
Message 17 of 88
Rebooted Hub & now says E016 with new ‘status’ screen layout.
So does anyone know what has changed - any change log?
Message 18 of 88
BT don't publish a change log for firmware updates
DavidCo
Expert
Message 19 of 88
You are right, they never do.
Then users just have more to annoySmiley LOL
Gitfinger
Message 20 of 88
The 14-day reboot "feature" still lives on in the new software.
