imjolly
Message 21 of 317
Re: Smart Hub (6 type A) Firmware update.
I didn't expect the firmware update to make a difference to the '14 day reset'
having suffered from the 14 reset it just stopped all of a sudden and now my connection was at 96 days before it reset because of firmware update
its annoying but as long as it reconnects with same speed then that is all it is annoying
B13blues
Message 22 of 317
Yes i can live with one reboot every other week, i've had far worse down the years
tonyw1
Message 23 of 317
I'm still away, but according to my DDNS updates my router has not rebooted since 2nd June so I'm expecting a reboot and change of IP address tomorrow.
tonyw1
Message 24 of 317
Spot on time, a few minutes over 14 days and my Smart hub has rebooted.
imjolly
Message 25 of 317
the surprise when it reaches 15 days then 16   as I said mine cleared on it's own with no help from me apart from doing nothing
tonyw1
Message 26 of 317
That's odd, it's just rebooted again, after only 5 days, although last year when our type B did a firmware update when we were away it didn't settle down until we returned a few weeks later and pulled normal levels of data through it. Perhaps DLM gets confused when a line is barely used.
B13blues
Message 27 of 317
Mine rebooted on the 14 days again so no change.
glenhill68
Expert
Message 28 of 317
Mine has rebooted twice after about 7 days each time since the update.
DavidCo
Expert
Message 29 of 317
tonyw1
Message 30 of 317
I'm still away but my wife is home for a few days and the clocks on the oven and microwave are flashing so we had a power cut, which explains the router reboot on the 21st that was puzzling me, so it looks like the F/W update went smoothly and the smart hub is back into it's normal 14 day routine. Speedtest is giving 70down/18up, which is normal for my line.
