Message 1 of 1
Smart Hub 6A randomly restarts
Hi, noticed that my Smart seams to restart every week or so. The log always shows the same evens leading to the restart.
This is an extract from the log.
00:00:35, 01 Jan.
:The Modem has successfully powered up
00:00:35, 01 Jan.
:WDG Laststatus:: # Current boot was caused by Soft Reset (SAAF)
00:00:28, 01 Jan.
:The Modem underwent a warm reset15:56:33, 07 Dec.
:A device reset was performed (GUI/Button)
15:43:37, 07 Dec.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
15:43:37, 07 Dec.
:TR69 sending SetParameterValuesResponse message
15:43:37, 07 Dec.
ppp1:TR69 receiving SetParameterValues message
15:43:37, 07 Dec.
15:43:37, 07 Dec.
15:43:35, 07 Dec.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
15:43:35, 07 Dec.
ppp1:TR69 receiving InformResponse message
15:43:34, 07 Dec.
ppp1:TR69 event found : 4 VALUE CHANGE
15:43:34, 07 Dec.
ppp1:TR69 event found : 2 PERIODIC
15:43:33, 07 Dec.
ppp1:TR69 sending Inform message
15:43:31, 07 Dec.
15:43:31, 07 Dec.
15:43:30, 07 Dec.
15:43:28, 07 Dec.
ppp1:TR69 creating new session with ACS
Any ideas.
