SellyGuy
Message 1 of 5
Smart Hub firmware update on Plusnet
Hi
I’ve noticed that my BT Smart Hub is still on the May 2018 firmware and hasn’t updated. Is the fact that it’s connected to Plusnet, rather than BT Broadband, preventing it updating? Thanks.
4 REPLIES 4
-Richie-
Expert
Message 2 of 5
Re: Smart Hub firmware update on Plusnet
If you're with Plusnet now then you might not ever get another update from BT, don't plusnet use a rebranded smart hub ?
Message 3 of 5
You could ask on the Plusnet user forum. Plusnet would not use BTs CWMP, which is probably why its not been updated.
B13blues
Message 4 of 5
SG4B1000B540
Firmware updated:
21-Apr-2018
This is the firmware i'm on with BT dated before yours.
SellyGuy
Message 5 of 5
I’m on the same version - the Hub just updated a bit later.
I bought the Smart Hub as an upgrade for the one which comes with Plusnet - a rebranded Home Hub 5. I’ve noticed it hasn’t updated to the latest firmware version - From Keith’s posting, it sounds as if it may not do so on BT’s network.
