Message 1 of 4
Smart Hub firmware version.
Hi all. I had a quick search but answers were a bit old.
What is the latest firmware on the smart hub?
I'm on
Firmware version:
v0.24.04.11017-BT
Firmware updated:
22-Mar-2021
Dave
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
3 REPLIES 3
Message 2 of 4
Re: Smart Hub firmware version.
SH1 or SH2?
My Sh2 was updated on 16-Apr-2021 to v0.26.03.01286-BT
Message 3 of 4
My Smart hub 2 was updated to  v0.26.03.01286-BT, on 1st April.
I remember that your v0.24.04.11017-BT, was the previous version. Don't know date of install however.
Message 4 of 4
@Devon_Dave
you are better off sticking with your current firmware as the recent update 1286 is the one that is causing wifi problems and is being replace sometime this month
