Bramshot
Message 1 of 6
Smart Hub help facility
I can’t find the help facility in my smart hub manager.  According to the embedded user manual there should be a ? In a circle symbol but this does not appear anywhere. What I am really after is something that will tell me what the little symbols in a blue box mean that appear in the device symbol box. The one I am unsure of is a ‘D’.
5 REPLIES 5
NeilO
Moderator
Moderator
Message 2 of 6
Re: Smart Hub help facility
@Bramshot Can you post a screen shot of the screen you're looking at with the symbol and we'll take a look?
Bramshot
Message 3 of 6
How? I have a screen shot, click the camera icon, and get asked for source, what do I give? Using iPad.
NeilO
Moderator
Moderator
Message 4 of 6
@Bramshot you need to save it as a document or picture.
Bramshot
Message 5 of 6
Bramshot
Message 6 of 6
I take it nobody knows the answer to this one then?  I suspect it might signify a dual band device, but can’t find a key anywhere.
