skier1
Message 11 of 33
Re: Smart Hub latest Firmware
Just checked mine and firmware is  0.09.05.11160. Is that a later or earlier release.
ojobson
Message 12 of 33
Latest release is SG4B1000B540 ... where did you find that string of numbers? It doesn't have the format of a typical version number.
___________________________________
My Blog: oliverjobson.co.uk | My FTTP install experience | Why can't I order Fibre broadband?
Dippu
Expert
Message 13 of 33
It doesn’t seem to follow the format are you sure you have Smart Hub (home hub 6) ?
Richardflea
Message 14 of 33
Can confirm I have this firmware version as well - it's a brand new v6 smart hub
Dippu
Expert
Message 15 of 33
Interesting and unusual for BT to deviate from the norm! So I am unable to answer your question
skier1
Message 16 of 33
Thanks Richardflea
My concern is that a recent AVG scan is warning of a serious DNS vulnerability and I'm trying to see if it's real or not
imjolly
Message 17 of 33
@skier1  I think it was Avast not AVG and it is covered here https://community.bt.com/t5/BT-Devices/Avast-reports-smarthub-vulnerable-to-attack/m-p/1822124
ojobson
Message 18 of 33
Hmm - a firmware with a version number less than 1 - that doesn't sound overly reassuring. Under normal versioning you would expect that to be a beta or pre-release version.
What service do you use - ADSL, FTTC, FTTC G.Fast, FTTP (+/- Ultrafast)? Perhaps the firmware is specific to a smart hub model that is used on a particular service, maybe something fairly new.
What is the first part of your serial number (the bit inbetween the two '+' symbols)? - this first part tells you the model number of router that you have. The router Type is also listed on the back of the hub, behind the slide out credentials card.
For instance my Smart Hub is a Type A, the model number is 084318 and I have firmware version SG4B1000B540.
drguiom
Message 19 of 33
def broken. I have UDP port 4500 forwarding breaking, works a a minute then stops. buffer overflow ?
this is for inbound L2TP connections. was fine 2 weeks ago
Zurdo
Message 20 of 33
I just recently set up a Smart Hub 6 sent out early May and can confirm the latest firmware it downloaded in the night as -
Firmware version:v0.09.05.11160-BT
Firmware updated:Thu Jun 7 00:25:24 2018
The item code is also different. It’s 088044.
