Mrlewisuk
Message 1 of 5
Smart hub 2 and smart plugs
I changed to smart hub 2 and got all my devices working by turning 5ghz off then back on for other devices which can use 5ghz
i have Alexa setup and all working until i tried smart sockets, which i tried first at parents house using virgin router with split wifi, so i know sockets work with Alexa
but when i got home and setup they connect ok and can turn on/off using app but when i ask Alexa to turn on or off she says ok and nothing happens.
i am quite technical as an electrician tech but this is driving round the bend
4 REPLIES 4
Devon_Dave
Distinguished Guru
Message 2 of 5
Re: Smart hub 2 and smart plugs
Try turning off smart set-up.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Mrlewisuk
Message 3 of 5
Tried all that and tried setting up from scratch and set to group and checking router settings for anything i have missed but still Alexa won’t turn plug on or off even after saying ok. But will turn on/off if i click in app
it worked on another router no problems
Keith_Beddoe
Message 4 of 5
Its probably best to go back to using the other router, as other people have reported similar problems with the smart hub 2.
Try it with the 5GHz wireless off all of the time, and see if it works.
Alexa issues https://community.bt.com/t5/BT-Devices/Smart-hub-2-settings/m-p/1916021#M7708
and again https://community.bt.com/t5/BT-Devices/Smart-hub-2-settings/m-p/1915724#M7691
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Introducing-Complete-Wi-Fi-from-BT/m-p/1917262#...
Issue with a smart TV https://community.bt.com/t5/Home-setup-Wi-Fi-network/Smart-hub-2-issue/m-p/1917672#M159617
and CCTV https://community.bt.com/t5/Home-setup-Wi-Fi-network/Smart-Hub-2/td-p/1917241
Heating controller https://community.bt.com/t5/BT-Devices/Is-there-a-way-to-restrict-wholehome-disk-s-to-2-4Ghz-only/m-...
Mrlewisuk
Message 5 of 5
Re: Smart hub 2 and smart plugs Fixed
I noticed that plugs connect to wifi on 2.4ghz and Alexa would say ok but nothing happened,
when i ask her to play a certain radio station she would mention my mothers Alexa name but its registered under mine, then i noticed home share and she was in that and when i turned her off everything worked
i am using smart life and hyleton plugs from Amazon
